Hi all.
I am taking my C5 Z06 to the shop to recheck the rear
shock mounts (aftermarket, they worked loose once).
It's been 6 months, so while it's up on the rack, what
else would you check for wear or damage on a car that
you'd want in tip-top shape for autocross?
Thanks!
I would check the sway bar end links and brakes. A general inspection for any leaks from differential/trans. Check tire wear also, much easier to see while it is up in the air.
