Had a little time today so I deciding to try out my new air ratchet, came in real handy for this install (that alot of bolts). It's the abs of steel reinforcement plate. I got the 1/4 aluminum ceramic coated verison. Easy install, just drop your pipes and start backing out bolts.
Not yet, but from what I have read guys that have did the swap said that they could tell the car was more rigid and the ceramic coating helped reduce the interior heat from the exhaust.
Sweeeettt ...Looks like an X pipe welded in to your stock exhaust. That true?
Not stock exhaust, it's FLP headers, high flow cats and X pipe.
Got it on a GP over two years ago. All the pipes came with the kit.
Kewl :cool: :ity:
