These plugs were put in when I had the re-ring done in January 2004, so they've been in a bit over a year. I'd say I put 12k on the car since then. When I had it dyno'd the car was running 11.5:1 up top at WOT. The car gets soot from fuel on the back of it at track events so I know it's a bit rich at WOT. Take a look at my plugs... is this "ok" or should i get her tuned? I was wanting to hold off on the tune until I got a cam.
It's a little hard to tell from the pictures. IMO your OK, not perfect but not bad. :cheers:
Number #8 looks little suspect.
It doesn't look too bad. Definitely running rich, but nothing to be concerned about. You can hold off on the tune until you get your cam.
Most of those look fine, all do except that bottom row left plug, it looks way rich. All plugs should have a reddish brown tint to them because of the fuel additives and unless you ran around all day @ WOT you shouldnt have a problem with rich/lean. My understanding is that a tune is going to correct WOT richness. On the dyno my car ran fine (relative to rich/lean) until they did the dyno pull. My a/f went from 14's at part throttle and accell to 10-11 @ WOT.
