So I have been doing research on this great forum we have about lowering my 02. As I jumped further into the topic I started getting different answers and opinions. I want to lower the car more than the factory will allow. So for the front, I have been told 2 options. First is to cut the stock bushings. Second is to order the hardbar kit with new bushings. Some people say that with the stock bushings cut you will get a squeak, others say no squeak. As far as the rear, some people have said go spend $15 at the local hardware store and get some grade 8 9/16" bolts and hardware (which I already did) while others have said to order the hardbar or WCC kit with the hardware and new poly bushings. Again, some said without the bushings you will squeak while others didn't. The pros I see are that by not cutting the factory stuff I will be able to return it to stock if desired. The bad part is the money! I think it is $140 for both kits. So jump in an flood me with your opinions and experience. Thanks!!! (sorry for the long post)
Mike :z:
Mike :z:
