I don't think the oil level will vary other than go down as it uses some oil. I think the reason thay say do not add if in the crosshatched area it to keep someone from adding a full quart when it is less than a quart down and over filling it. I do not see any harm in adding at any time as long as you do not over fill it.
I believe the reason for the length of the crosshatched area is just due to the diameter of the oil tank. Maybe someone here knows for sure but I think it is 1qt. low when at the bottom of the crosshatched area.
