UQ5 is an extended range 4 way speaker system, I believe.
On 2001-04-11 10:40, M3NOMORE spewed forth this drivel:
Does anybody know the GM part number for the 12 disk CD Changer and harness that will work in our Zs? And what is option UQ5? Thanks.
Mike
Frank:
The part # for the 12 disk changer that comes from the factory is 25685332.
If you order the changer from GM, these are the part #'s you will need.
Order from www.gmpartsdirect. MUCH cheaper!!
Changer 12495746 List: $496.00 GMPD: $297.00
Installation Kit 12497876 List: $120 GMPD: $72.00
Hope that is what you were looking for.
On 2001-04-11 15:50, M3NOMORE spewed forth this drivel:
Mike,
One more question Frank... Do you know everything? 'Cause I've got this problem with this chick...
The kit is suppose to contain the wiring harness and mounting bracket.
Problem with a chick?? Send over here...when I'm done with her, she'll forget all about you!! /phpBB/images/smiles/icon_lol.gif Hope Sherylann isn't reading this!! /phpBB/images/smiles/icon_eek.gif
It installs vertically in the center compartment at the rear.
On 2001-04-11 16:45, BOBSZ06 spewed forth this drivel:
I haven't seen a changer in a Corvette. Where does it install? In the center compartment? Does it sit vertically or horizontally? Easy to change the disk cassettes?
Thanks,
Thanks Frank, you can have her. Any particular delivery instructions? Such as plain brown wrapper holding a bottle of Tequila?
On 2001-04-11 16:10, fcalmes spewed forth this drivel:
