I noticed that under light acceleration or when revving the engine there is a light rattle that sounds like a catalytic converter, also there is a noise don't know if it is the same or another that happens when turning the car off. normal or am i off to the dealer??
When turning off the car, Let me guess... Car in neutral and clutch out.....If so noise is normal. If you have the clutch in then I would have the dealer look into it :cheers: :cheers:
The clutch out noise is normal. It is noted in the owners manual. It has something to do with the harmonics from the driveshaft tube. Sounds like marbles in there.
