Service VME - Brake Squeal and Brake Dust Accumulation - ABS TCS wheel #PI01320 - (Aug 18, 2003)
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
SERVICE VME
This is a service VME involving 2002 through 2004 Z06 Corvettes
Corvette (Y- Body) 2002, 2003 and 2004 Z06 Corvette Brake Squeal and Brake Dust Accumulation
The Corvette Z06 is equipped with high performance front brake linings that provide improved brake performance under severe use. Like all such linings, they will exhibit some low speed noise and an increase in the amount of brake dust. These conditions should be considered normal for this brake pad material. If this is a large customer dissatisfier, the front brake pads used on the convertible and Targa can be used as a replacement. The convertible and Targa brake pad will NOT provide the same level of performance under severe use.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
