Vrrooom said:Anyone know of a way to re-wire the stock headlights so that the low beam stays on when you turn on the high beam? Sorta like when you pull back on the stalk how they both stay on.
maineyak_2000 said:I was thinking of doing that with the stock lights too.....
can you supply data on the PIA Driving lights...Model /price/Specs/Available at ??
IT L GO said:
Are you doing the HID conversion with the OEM reflectors?Vrrooom said:Thank you. Now to find out where exactly the dimmer switch is on the Corvettes.
I was actually thinking of going with a 4300k HID low beam, and then have the brights if I need it at all. Since HIDs have a sharper cut off.
