1 - 2 of 2 Posts
Hey all. I will be getting my dte stage 2 rear end here pretty soon. I was wondering if u could give me any input about the tool u need for the suspension when removing the rear diff and transmission. CAn this be mickey moused with something eles or do i need the tool? If so...where can i pruchase this tool?
Another question for ya.
i will be putting on my mickey ets on........how do i bypass the run flat sensor so i can run these tires? any help would be greatley appriciated!
No real specific tool needed for rear removal and your air pressure sensors are part of your valve stem, so if you are using the same wheels (I am guessing that you had them installed since a Z06 didnt come with the tire pressure sensor) then you will still have them in the wheel with the new tires
1 - 2 of 2 Posts
