1 - 2 of 2 Posts
I took the car in for an oil change ( doing it myslef is a day long job for me) and the guy told me there was a slight leak from the rear dif. I can see there is fluid covering the rear end on the drivers side but not enough to leak on the drive way. Should I take it in for a fixin?????? I do have the GMPP extended warranty and my regular warranty just ran out last month. Dr.Bigg
Pretty common problem. I think mine's been done three times. But OK after the third try for the last two years. There is a TSB for this and should be covered under the GMPP. Mine happenned under the original warranty.
1 - 2 of 2 Posts
