I was driving on an interstate (traction control OFF) at 70 mph in 6th gear. To pass, I downshifted to 5th and accelerated to 100 mph. When I eased off the gas, the rear end started to shake and vibrate as if I had 2 flat tires. I slowed down and pulled off the road to look at the rear tires. I turned off the engine and examined the rear end. The tires were OK. I found NO problem. I restarted the car and drove another hour under similar conditions without a recurrence of the problem. It seems to me the problem (ABS? Traction control?) was under computer control and when I restarted the engine, the computer was rebooted.
Has anybody out there experienced similar problems with the Z06?
