Can anyone recommend a dealer in Miami who knows how to fix this problem?
Car is 03 Z06 with 17,700 miles.
Is it still on warranty?
There is no grinding or anything, it just has to be beat out of 4th when it gets stuck.
TIA
I say take it to any dealership to look at it and expect them to replace that tranny if its still under warranty.
Try not to drive it any more. My friend had the same issue and we drove it around and tried to shift it over and over into neutral and back in 4th, etc.
When we got it tore apart, the syncros were completly gone and minor gear damage, so don't drive it anymore.
Have it towed. Also, if you DO decide to do it at a dealership and not a 3rd party corvette place, make sure they don't just replace one thing but more so the entire unit.
Also the main cause of this is probably a bent shift fork. Which they MIGHT just replace that and send you on your way.
Tony
I forgot to mention...the car has heads, headers, cam, etc.
Does this void the tranny warranty?
Shouldn't void the warranty but some dealers will charge you some labor to remove the headers.
