1 - 1 of 1 Posts
Vendor
If you want to refresh the appearance of your Chevy Corvette C6 and give it a modern LED light accent - you should definitely check out new custom headlights by Morimoto. While there is plenty of aftermarket options available for these cars, not all of them actually improve the light output right out of the box.
Morimoto XB DRL Bar Projector LED Headlights do. They are now available at CARiD for 2003-2013 Chevy Corvette C6 models. They produce a sharp beam pattern with a great amount of width, intensity, and a proper distribution of light that will outperform your factory setup.
Morimoto® LF460 - XB™ Black DRL Bar Projector LED Headlights with Sequential Turn Signal at CARiD.com
Features:
- Includes 2 Headlights and flicker/hyper flash modules
- DRL/running light color: white
- Turn signal color: amber
- Operating voltage: 9-32V DC
- Lens material: UV-coated polycarbonate
- Housing material: PPS plastic
- LED optics: Kuria Bi-LED optics
- DOT, ECE, SAE, FMVSS compliance
- Plug-n-play installation
- Backed by a 5-year limited warranty from Morimoto.
View more Morimoto LED Fog Lights, HID Projectors, Bulbs at CARiD.com
Get an excellent light output and stylish upgrade for your Corvette with Morimoto Headlights on!​
1 - 1 of 1 Posts
