I was exiting a freeway. Upon entering the offramp, I was doing about 100 mph, and there was a sharp 120 degree right hand turn. I heal-and-toed from 4th into 2nd (actually engaging each gear - have you ever heal-and-toed over multiple downshifts?) and at the apex of the turn I nailed it in second. I was doing about 50 mph at this point when I nailed it, and I got the expected over steer. Usually AH lights up a bit at this point (front outside brake) to help straighten out the turn (thank you very much AH). But this time, I seemd to get a bit of oscillation left and right - the car seemed to fish tail left and right, and AH stayed on longer than usual. Though there's no way I could tell for sure, it seemed as if the AH was alternating between the left and right front brake.
Though I was not in competitive driving mode (meaing TC was enabled), traction control did not light up, as I am pretty good at this point at not lighting up the rears as I swing through a corner.
Has anyone else experienced this kind of swinging left and right, when the rears are *not* spinning (TC did not light up), and AH is doing its thing?
