Just starting to have problems shifting from 4th to 5th..seems like shifter is hanging up on reverse..i know the manual trans.has a lock-out function..severe grinding if too much pressure on the shift..anyone ever hear of a problem pertaining to this? car was delivered 9/10 apox 1500 miles..:-?
Reverse lockout solenoid
Hi there,
The reverse lockout solenoid engages when the speedo hits 3 mph. This will effectively lock out this type of concern.
You tech should check for proper travel of the solenoid, as my guess would be that this is not travelling far enough to correctly lock out reverse.
Your dealer can easily test the solenoid, and determine correct repairs, bestto you, c4c5
Thanks for the info,c4c5 specialist.. problem sounds minor,guess i will have to visit a local chevy dealer :(
