1 - 8 of 8 Posts
Car is getting really cranky about going into reverse. I usually row through a couple of gears and the go to R. but sometimes this doesn't help. Anyone else have this problem? I hate to have the dealer pull the trans, but it looks like I'm heading this way./Dave
Have you checked the connections to the reverse gear solenoid on top of trans.??
Sounds like it's time to visit the Dealer. If you have an aftermarket shifter installed, put the stock one back in before you go. Let us know how you make out :cheers:
I've got a similar problem. Seems to occurr more regularly with the car warmed up well. I chatted with a local tech who says it could be a simple linkage adjustment or a bad rev syncro gear.
Mine does it too. Sometimes it grinds when in reverse. Let us know what the stealer (dealer) says. :p
1 - 8 of 8 Posts
