Hey guys, I'm planning on installing the Ripper that I had in my '01 Coupe into my '03 Z06. I noticed on B&M's site that it was listed as "97-02" - will the Ripper I bought in '01 not fit the '03 Z06? I can't see this as being the case but figured I'd ask anyway...
Also, I may be missing the rubber boot that comes with the ripper, big deal or no? The gasket and retainer ring I believe I have...
Thanks...
The Ripper from your 01 will fit your 03 just fine. :z:
Whatever you've misplaced, insulation-wise, I'd either try to track down or consider fabbing something like it. Most of the aftermarket shifters transmit noise, and so you'll probably want all of the insulating material you can use.
-Kirk
