1 - 12 of 12 Posts
Has anyone considered or put roller rockers on your Z06. I found this to be an effective HP gain on other cars. It decreases friction and you can also get higher ratio rockers to increase valve lift. Anyone have experience or information on them. I feel on an 01' this could compensate for the slightly larger cam on the 02'. It is a fairly easy mod I am considering, but I don't want to do it blindly, any info would help.
crane cams have them,but they cost as much as a cam change. LS-1 ASA race engines which make 440 HP and turn 6800 RPM use stock rocker arms which have needle bearing pivot.
Roller rockers are made for the LS1/LS6 engine, I will find out more when I go to the shop that is doing my engine, they are putting them in when the do the heads and cam and other things. /phpBB/images/smiles/icon_wink.gif
I have the Crane 1.8 on my car.
_________________
border=0> 2001 Z06 BLACK/BLACK<P>MAY THE TORQUE BE WITH YOU!<P>HENNESSEY MOTORSPORTS
Z500 #1<P>500 HP & 471 TQ
425.3 RWHP & 400.3 RWTQ (SAE 0.93 CF)<P>
Steve...I have the stock rocker assembly with 428.2 rh & 400.9 rt!! With the cam I used, piston to valve clearance would have been an issue with the 1.8s', unless I wanted to go in and cut some relief in the top of the pistons!!
Anyway, off to work I go, Catch up with you guys in a week!!
ASASN
BTW, Darth V., sorry I didn't get to take a ride in your car after we spoke, I left Houston hours before the rains came!! I enjoyed speaking with you, hopefully we'll talk again soon!! Glad to see you back!!
1 - 12 of 12 Posts
