Got a coupon from the dealer 29.95 to have tires rotated should i have it done does it need it and what the heck does it mean?
Eagle F1 SC tires are ASYMMETRICAL but NOT directional, so yes they can be swapped from one side to the other. Some folks do this at the track every time they take it out, as most tracks are right or left turn biased, thus wearing one side faster than the other. Many others have done this many times, and driven hard at speeds in excess of 137mph, and have had not a single problem. Goodyear confirms that this is acceptable for these tires by calling their tech line at 1-800-387-3288. Any dealer with a knowledgeable rep will also confirm that the tires are not bothered by being swapped left-to-right.Pbalias said:Then it was a mistake. There's no "rotating" our tires cause of the size difference, and i think the F1's are directional, aren't they? That means no swapping them side to side either, unless you break them off the rim and mount them on the other side, which would be defeating the whole purpose anyway.
I thought you could with the runflats on a C5, you just have to take the tire off the wheel then swap with the other tire to rotate them; the GY Gatorbacks were/are the same way.IT L GO said:The Owners manual specifically addresses rotation, as in 4 wheel rotation, which cannot be done, for obvious reasons. Further, the owners manual is not specifically addressing the Z06, it addresses the C5 in general, which uses symmetrical DIRECTIONAL tires (Run Flats). These cannot be reversed (side-to-side), as the water channels would not function properly. However, I have also seen these reversed at track events on dry pavement to increase tire life, again with no ill effects. They just have to be put back on their correct corner before any wet conditions occur.
http://www.z06vette.com/forums/showthread.php?t=93989&highlight=directional
The C5 in general, which uses symmetrical DIRECTIONAL tires (Run Flats). These cannot be reversed (side-to-side), as the water channels would not function properly. However, I have also seen these reversed at track events on dry pavement to increase tire life, again with no ill effects. They just have to be put back on their correct corner before any wet conditions occur.Millenium Z06 said:I thought you could with the runflats on a C5, you just have to take the tire off the wheel then swap with the other tire to rotate them; the GY Gatorbacks were/are the same way.
IT L GO covered the actual tire issue very well above.burnout said:Got a coupon from the dealer 29.95 to have tires rotated should i have it done does it need it and what the heck does it mean?
Geeze, maybe this is something I should look in to... my tires have always seemed to rotate just fine by themselves, but if Chevy dealers are sending out coupons, maybe my tires aren't rotating at all and I've just never noticed! :rofl:burnout said:Got a coupon from the dealer 29.95 to have tires rotated should i have it done does it need it and what the heck does it mean?
