So my car has just over 20K miles and I've had it since Nov.
When I stop under very light braking like to brake in a parking lot for a speed bump they sqeal so I am wondering if that is the squeal indicators and I need pads.
Car is not tracked except it's been to the drags once and there is alot of shutdown room. It will probably never see a track or auto x but I want it to stop on a dime.
If that is the case should I buy pads and turn my rotors or buy pads and rotors ?
Which Pads for the stock rotors if I just turn them ?
Which rotor and pad combo if I decide to replace the rotors ?
Thanks,
Pat
IMO don't turn your rotors, buy new from NAPA etc. 100.00 for all 4 :cheers:
Are your sqeal tabs touching the rotor? You should be able to tell by looking if the pads are that worn.
Most new vette brakes squeal with very few miles. :bmad:
I would get ceramic brakes and some kool rotors -- slotted and drilled! ;)
I'm not sure I am getting a good look at it with the wheel on.
I'm gonna have to take the wheel off and check to be sure.
