Need a clutch for my Procharged 2004 ZO6(530HP rearwheels and Nitto Drags). What are you guys using with success. It must be usable for a daily driver. I don't mind some increased pedal effort but don't need a work out driving to work everyday.
I have a Spec stage III with their aluminum flywheel. There is some chatter but it diminishes with time. The pedal effort is pretty much stock. I do have to suggest that you get a McLeod adjustable master cylinder. I had engagement issues and the only fix was the adjustable master cylinder. So far no problems with 568 rwhp.
Jim
I have a Spec 2/3 Hybrid, their Aluminum Flywheel and their lightweight-option pressure plate.
The clutch is pretty cool, Kevlar on one side, Ceramic on the other. Supposed to be almost as "smooth" as a stage 2, with almost the grip of a stage 3.
The PP is cross drilled and machined to remove some of the rotating mass.
Pedal effort was unaffected. The engagement range was a little "shorter", but still about in the middle of the pedal throw, which is where it had been with the stock clutch.
It did chatter quite a bit, and for more miles than Spec's instructions said it would, but I did drive it to Florida and back right after the installation so it had a lot of no-shift highway miles. It's finally quieting down, now, though. If I take out the Florida miles, it needed about 1K miles to break in vs. a Spec claimed 500.
I also have the Spec stage III
It has lots of track time and no prob.
530 rwhp
Darwin.
Luk Pro Gold :coo: :yeadog: doing me fine :yeadog:
