Common issue. Many articles covering it on this forum.
What I have noticed is that short of an actual component failure, it is one of the messages you get as your battery and or charging system nears the end of it's usefull life.
SOunds more seirous than it really is - besides which, GM have not been able to cure the problem after having shipped over 200,000 C5's.
Their answer is a hardware change (eliminate column lock) on auto cars - and a software fix that forces a tow if the issue comes up on 6 speed cars.
BTW, welcome to "Column Lock Anonymous" ;)
Do a search on the forum and you will finda lot of people in the same boat as yourself. There are few inexpensive ways to fix it.
