Please pick one of the poll options below.
  • Who has or wants a B&M Ripper?
    Votes: 82 46.6%
  • Who has or wants a Kirban?
    Votes: 24 13.6%
  • Who wants a Hurst (if it every comes out)
    Votes: 44 25.0%
  • Who had a Ripper and swapped to a Kirban?
    Votes: 0 0.0%
  • Who had a Kirban and swapped to a Ripper?
    Votes: 1 0.6%
  • Who had a Kirban or Ripper and went back stock?
    Votes: 3 1.7%
  • Who is still stock and will stay that way?
    Votes: 22 12.5%
1 - 20 of 49 Posts
Ya, this poll thing is kind of cool. Hopefully, this will help people get an idea what's being used by most of the owners, and what people plan on buying. Hope everyone participates :D.
We have had very good reviews on the Kirban as we started carrying it. It's easier to use than the Ripper. Wives like it:)
We've sold a ton of Rippers, though. Seems to be the standard so afr, but, Hurst is close to relaeasing theirs.
RG
Geez.. Then there's me who tried the Kirban and pulled it right out, then tried the CC Speed Shifter and yanked that, then installed the Ripper -- and really enjoy it, but wonder if the Hurst will be "better," since it was so good in my Mustang... :rolleyes:
Oh well -- at least I'm REALLY good at installing shifters now! I can do one in 20 minutes! :D
The Ripper is staying, assuming that the Hurst never makes it to market. :)
-Kirk
Mako said:
Had the ripper, took it out after 3 days. Went back to stock and had the shifter shortened and I think it is great!
Mako... just curious about what you disliked about the Ripper? :(
Also... what makes a shortened stock shifter more suitable for you? :)
BTW remember I am just curious... I am glad you found an improved shifter that works for you.
<< Same as Mako--took the
Ripper out--ok for me but wife coud not shift it on a road coarse--just to hard to leverage the handle for her--lubed it-no springs to remove. But if Hurst ever goes ito production,will give it a try.
I'm not Mako, but I had a Corvette Concepts Speed Shifter (essentially a cut-down stock shifter) in my car for a couple days -- so I know what they're like.
I imagine that Mako didn't like the stiffness of the Ripper. The cut-down stock shifter has all the ease of the stock shifter's shifting ability, but without such a long stick. The problems that I found with this were:
1) The throws (front-to-back-to-front) were still too long and sloppy (that's not resolved with a cut-down shifter). Still feels like you're rowing a boat.
2) Since the stock shifter gets wider at the base, the leather boot opening at the top (that slips down over the stick) doesn't want to go down over the fat part (base) of the shifter, leaving you to squash it down with most shift knobs. Also, I imagine that any shift knob that is meant to thread down low on the stick will only go half way before hitting the wide base of the stock shifter.
This was my experience. Hope it helps!
-Kirk
What's best for serious road racing?
In the good ole days, heavy clutch action generally kept the chicks from wanting to drive your 'vette.
With modern clutch engineering, we now have to rely on heavy shifter springs..
I'm wondering what to do for a shifter in my Z.
I primarily road race, not drag race. Good heel'n toe downshift performance under heavy braking is generally a lot more important to me than the upshift performance. A good day at the track may mean 1000 to 1400 shifts.
The heavy, non-adjustable spring in the Ripper may be a bit much for that application.
What do you guys prefer for road racing?
Thanks!
Re: What's best for serious road racing?
Thanks!
Brian,
Whereas I don't road race (in sanctioned events, that is ;)), I like the way the Ripper slots so positively into gear -- and the RIGHT gear at that. Once you get used to the Ripper, there's no having to guess which gear you're in, which I'd think would be a big plus in road racing.
Also, the Ripper's so solid that you can use it to "hold on" when making quick right-handers! :D
The Ripper IS pretty stiff -- but all of it's [other] pluses might outweigh the stiffness issue.
-Kirk
I Love This Combo... after 2800 miles, IT ONLY GETS BETTER!
HarleyB:z:
1 - 20 of 49 Posts
