How bad is the smell w/o cats? I didn't have cats on my Cobra, and it wasn't too bad. How does the Z06 smell w/o cats?
Antivenom 447 said:Let's say this.......... If you could run pump gas in my card you'd puke from the fumes but since I run a special blend of pump gasit smells like fruit so I don't mind getting high while I drive and it's 50 state legal just not the 50 states in the USA :rofl:
Yep...I have the G5X3 w/ heads. Prior to the heads install, I was cam only w/ the cats (Kooks headers) and there was still an unburned gas smell. With the heads install, I had the cats removed and the unburned gas smell definately got stronger. Does wonders for your gas mileage :lol: , but the added zip is worth it for sure. :jammin:BajaZ06 said:I've got a H/C car with LGM long tubes, MM cats and a G5X-3 cam. With this cams overlap it puts out the raw unburned gas smell even with the cats. About a month ago I had it re-tuned and removed the cats. The smell is worse now without the cats.
As others have said you must air the garage out about 10 min after you pull in and the smell does tend to stick to you. I think the smell is about the cam size and the amount of overlap it has.
Bill
Antivenom 447 said:Let's say this.......... If you could run pump gas in my car you'd puke from the fumes but since I run a special blend of pump gasit smells like fruit so I don't mind getting high while I drive and it's 50 state legal just not the 50 states in the USA :rofl:
I actually open the driver door at a stoplight to smell it or I stand at the rear of the car when I first start it up I love the smell so much. :screwy:TheAngryTiTTy said::lol: Nothing beats the fruity smell of race gas... :yeadog: :yeadog:
