1 - 8 of 8 Posts
I just pulled the first plug and the aluminum heat shield came off with it!! Is this suppose to happen? Do these heat shields need to go back on the new wires? PLEASE HELP!!!!
I'm assuming that you are talking about the plug wire. The shield stays with the wire. You can take it off of the wire, but it won't fit most aftermarket wires. Rememer to use dialectric grease when re-installing the new wires!
-matt
I am useing MSD wires. Do I need To put the Aluminum shield from the factory wires on the MSD wires or leave them off?
You can leave them off SGT PYLE. If you have headers then I recommend Kool socks to go over the wires. MSD has a good silicone boot you should not have any problems. :cheers:
dwjZ06 said:
You can leave them off SGT PYLE. If you have headers then I reccomend Kool socks to go over the wires. MSD has a good silicone boot you should not have any problems. :cheers:
Thanks alot dwjZO6 and ss2zo6! :cheers: I just got finished and she started right up! :jammin: Seems to start stronger so now I am about to go for a spin. I dont expect to feel any difference in power but I was really just curious to see if I was mechanically enclined enough to change the plugs and wires myself. Thanks Again!!! :guiness:
Congrats on the plug change. The rear one on the driver's side is a PITA, isn't it? :lol:
My car always feels stronger with new plugs. These plugs may last 100k miles, but they foul way before that point... I'm now changing mine out every couple of races.
The rear one was a little difficult. Just did my plugs this last weekend. Now I got the hang of it though...
Sgt Pyle: what plugs did you use? I used the TR55s.
Car likes them! :thumb:
I also use the TR-55's. I'm glad to see that everything turned out good!
-matt
1 - 8 of 8 Posts
