mmorse,
Easy to fix this annoying problem.
Couple squirts of WD40 on each of the headlamp pivot points will quiet them down. Each headlamp has two pivot point which are easy to see if you lift the hood and look into the headlamp assembly while a helper raises and lowers the lights several times. Silicone spray or lithium (white) grease will also do the trick.
Ranger
