1 - 10 of 10 Posts
My car is going to need 3 new pistons, and new valves. Pushrods DID NOT bend, instead the valves hit the pistons. It's a suprise to me. This happened from a mechanical overrev. Big mistake on my part.
Good to here, you got lucky. Did you have a stock shifter?
Surfnerv89 said:
They are going to cover it under warranty. Yes!! They said the only way it could happen is the a downshift to occur, and the engine to be overreved. They said they would replace the broken parts one time.
Sounds like you have a good dealer ... surprised me to hear they are going to cover it under warranty even though they knew it was caused by operator error. :coo:
Good luck with the repairs.
Discussion Starter · #9 ·
02Redzo6 said:
What gear did you put it in and at what speed? Just curious. I had a few close calls and then i ordered a hurst.
It was the top of third, around 100. Down to second.
Thanks for the support. My first time dealing with a Chevy dealership, and it's turning out very good.
1 - 10 of 10 Posts
