1 - 10 of 10 Posts
What are the actual mechanical parts that are different between a stock '02 Z06 suspension and a T-1 Suspension Kit that is approx 3.5K?
Regards,
Paul:cheers:
Regards,
Paul:cheers:
12480062 T1 Suspension Package 1999/2000
This package inlcudes the following items:
12480063 Spring - Front 1999/2000
12480064 Spring - Rear 1999/2000
12480065 Bar - Anti-Roll Front 1999/2000
12480066 Bar - Anti-Roll Rear 1999/2000
12480067 Link - Anti-Roll Bar 1999/2000
12480068 Isolator - Front Anti-Roll Bar 1999/2000
12480069 Isolator - Rear Anti-Roll Bar 1999/2000
12480072 Arm - Front Upper LH 1999/2000
12480073 Arm - Front Upper RH 1999/2000
12480077 Arm - Front Lower LH 1999/2000
12480078 Arm - Front Lower RH 1999/2000
Specially tuned SACHS Shocks for the T1 Suspension Kit
12480094 Shock - TI Front 1999/2000
12480095 Shock - TI Rear 1999/2000
12480093 C5 Camber Spacer Kit Parts
12480071 Plate - Camber Large 1999/2000
12480076 Plate - Camber Small 1999/2000
15688265 Bolt - Lower Control Arm 1999/2000
11516382 Nut - Lower Control Arm
The arms are replaced not because they are different, but because they have a stiffer bushing inside. To keep us from tearing out our hair replacing the bushings in the stock arms, they did this. Possibly also so that you can put back on all original parts when you are ready to sell.
Now the million dollar question. Does anyone have the specs for this stuff. spring rates, antiroll bar thinckness etc... It would be interesting to compare. And great knowledge for anyone looking to make the swap.
Wheel rate would be a bit more informative. Then if you had the wheel rates for, hmm, say DRM's coil-over package you could easily compare.
Alas I know nothing of the actual rates.
1 - 10 of 10 Posts
