T1 Spec Line
YES.
The original SCCA T1 Series Spec. Line as listed in the GCR's(before the 2001 Z06) stated
"C5 Corvette, including Fixed Roof Coupe"
So the regular C5 Coupe was the original basis for the series. The FRC had a weight advantage, but all cars had to meet a minimum weight.
In 2001 the GCR's listed seperate Tech Spec. Lines for the C5 and Z06 (essentially identical).
These 2 Spec. Lines were later combined after 2002. Thus allowing all previos C5s to be updated to current Z06 Specs. ie. use the LS6 engine, close ratio tranny, T1 kit, DR radiator, etc.
Not too many folks run them though because of the extra weight. Heinricy will be running a C6 coupe at this year's runoffs because they don't have a FRC yet.
