1 - 2 of 2 Posts
Testing O2 sensors on the workbench.
Use a high impedance DC voltmeter (A acceptable value is 1,000,000 ohms/volt or more on the DC voltage. Most (if not all) digital voltmeters meet this need. ). Clamp the sensor in a vice, or use a plier or vice-grip to hold it. Clamp your negative voltmeter lead to the case, and the positive to the output wire. Use a propane torch set to high and the inner blue flame tip to heat the fluted or perforated area of the sensor. You should see a DC voltage of at least 0.6 within 20 seconds. If not, most likely cause is open circuit internally or lead fouling. If OK so far, remove from flame. You should see a drop to under 0.1 volt within 4 seconds. If not likely silicone fouled. If still OK, heat for two full minutes and watch for drops in voltage. Sometimes, the internal connections will open up under heat. This is the same a loose wire and is a failure. If the sensor is OK at this point, and will switch from high to low quickly as you move the flame, the sensor is good. Bear in mind that good or bad is relative, with port fuel injection needing faster information than carbureted systems.
ANY O2 sensor that will generate 0.9 volts or more when heated, show 0.1 volts or less within one second of flame removal, AND pass the two minute heat test is good regardless of age. When replacing a sensor, don't miss the opportunity to use the test above on the replacement. This will calibrate your evaluation skills and save you money in the future. There is almost always *no* benefit in replacing an oxygen sensor that will pass the test in the first line of this paragraph.
Z06 Tech Advisor
The problem with that testing is the output might be within the operating window but the heater of the 02 can be bad and the 02 is never getting hot enough
Add front 02s that are mounted further downstream due to added headers and what looks good with the above test does not say the 02 is good enough when in colder exhaust downstream
Also most cases people get suckered into extending/splicing the special 02 wires since they are now further downstream and with 02 operating only from 0 to 1 volt the extended wires cause a voltage drop from both PCM's 0.450 mVolt to 02 and voltage output from 02 and impedance change to the quad hardware in the PCM
02 wires are very special where there is a airpath in the wire so that 02 gets colder cleaner outside air to reference to
With extended wiring that kills off that flow and 02 reports incorrectly and above test would not test any of the above issues
Torch would cause 02 to get hot enough but exhaust design may not and if 02 is weak then good chance what is seen as a passing test of above would not work well enough in car.
1 - 2 of 2 Posts
