Well, LAPD says Hawk pads are on backorder, and the track is calling Friday. I'm not going to have new pads for the weekend. However...
I have my old ones from the last DE I did there. They are stock Z06 pads, with plenty of meat in them. They just got very hot last time. The rotors are pretty good, and should handle a day of track time without warping, but I have spares if it happens. My mechanic suggested that I save the old pads to use at the next DE.
The question is: Do I run the old pads or the new ones (the ones on the car)? What happens to stock pads when they get that hot?
Thanks.
--Yak
Why don't you call up Carbotech and get a set of their pads (XP9 or so).
I ordered a set for the WRX last monday, ordered 3 day select, the arrived friday, went in sat. And from what I've read, they're a better pad than the hawks anyway.
Not a bad idea, except that my budget is limited. I just paid LAPD quite a bit for those Hawks.
How are Carbotech pads on rotors? I heard they wore on 'em a bit harder.
--Yak
dunno, rotors are cheap
I just put my first set in, so we'll see.
Get LAPD to refund you, and order the carbotechs. They shouldnt have charged your card for somethign that was backordered anyway.
Carbotech is running slow now too, I just ordered today and it will be 2 weeks. I think everyone is busy filling Runoffs orders.
Seeing how expensive pads are versus cheap rotors, I'd much rather have the rotors go versus the pads.
I used Hawk Blues once and they worked great, but they left a toxic waste dump all over my car which was very hard to remove; I had to use a clay-bar to do so.
The last two times out at Road America (..very hard on brakes) I have been using Carbotech's and like 'em. Not only that, the residual brake debris is easily removed.
