1 - 2 of 2 Posts
Banned
Vehicle heater system does not heat can be divided into two reasons, first, the engine cooling system caused by poor control of one agency working heater caused during maintenance, we first determined which side of **EDITED**is the cause, then make the appropriate repairs.
Discrimination method is very simple, look at the small tank heater two inlet temperature, if the two pipes are hot enough, that is the problem of air flow control mechanism, on the contrary, if the two pipes are cold or a hot one cool, indicating a cooling system problem.
1 - 2 of 2 Posts
