1 - 10 of 10 Posts
Are the time chains on the 04 z06's diffrent than 03 and lower ls6 chains?
Thanks . . .
I am not sure.
Chevy does list a single roller HD Timing Chain with thicker alloy side plates in the 2003 Performance Parts Catalog. Part # 88958608.
In addition they have a Timing Chain Damper listed. Part # 88958607.
Wether or not these made it into '04 production is still a question.
Most racers just install a Cloyes or Rollmaster double roller. Cloyes has a "hex-adjust" unit that allows timing adjustments without keys.
SLP also has a stouter single roller similar to the Chevy HD one.
Thanks for your answer . . . I think I'm gonna go with a Roll Master Double Roller, so when I take my chain out I'll post the part no. stamped on it.
Actually 04 has the upgraded chain and dampner. I would stick with what you have. That is what everyone upgrades to. It is the same as the c6 and the c5r chain. Save the cash.
-matt
In the GM performance parts catalog the c5r timing chain is listed as a single.
That doesn't mean they use it. It might just mean that GM offers that part for use with the C5R block.
I installed a Katech single roller when I did my H/C package this past January. It is much heavier and fit way tighter than the stock chain, which had around 1/2 inch of "slop" in it when I pulled it out at just under 10k miles.
The new GM performance parts chain is the LS2 chain which is thicker than the 03-04 Ls6 chains...
I went with the Rollmaster Heat Treated Double roller - very stout piece and would recommend for $120.
1 - 10 of 10 Posts
