· Registered
Are the stock tires directional, I know they say this said outwards due to the unique tread pattern. If they aren't directional could you rotate the back 2 or the front 2. I am sure there is some reason you can't rotate. Well I hope this makes sense. Thanks
· Registered
Thanks for the help I was on the track this weekend and most of the corners where right-hand so the left rear tire was taking a beating. So rotated the tires halfway through the day and didn't notice any change or adverse effects. I noticed no problems driving home in the rain also.
· Registered
OK Frank, referring to the above thread. If the Eagle F1 Supercar Tires on our 2001 Z06s are not unidirectional. And all other Eagle F1 Supercar Tires are unidirectional. Then will replacement tires for our Z06s be unidirectional? /phpBB/images/smiles/icon_confused.gif
Mike
