1 - 2 of 2 Posts
Discussion Starter · #2 ·
One problem with tracking the C6 Z51 will be the tire pressure sensor issue. You apparently cannot just swap to your track tires and rims if they do not have tire pressure sensors. If you DO find track rims to which you can mount sensors or you have them customed-machined to accept sensors, then you still must reprogram the sensors to accept the new wheels each time you change and on a C6, as contrasted with a C5, you must have some special and expensive RF tool to do so.
What a mess--please see this thread from CF about the problem:
http://forums.corvetteforum.com/showthread.php?t=1140749&forum_id=101
1 - 2 of 2 Posts
