2003 Quicksilver Z06
Would changing tire size make this light come on? Traction control.
About 15 years ago, after super-inflating for autocross, I forgot to deflate back to norm and traction control went nuts . . . so I imagine changing tire size could also be detected. Might just need recalibration for the new tires?
Z06 Tech Advisor
Go to a website like this one
Tire compare
Insert the stock wheel/tire size and size on car now
see what the difference is
The larger the difference is the more apt it will trigger TC
If more than maybe 5% difference would be sure you need to go to a tuner who will
adjust in the PCM what size your using now to correct the problem
Also, could use a GPS that also shows MPH and compare that with what the speedo on dash
and see what the percentage difference is
