Status
Not open for further replies.
1 - 1 of 1 Posts
Clutch Pressure Plate Bolts (3 passes) = 20/40/52 Ft#
Seq. = 1-4-6-2-3-5
Flywheel Bolts (3 passes) = 15/37/74 Ft#
Seq. = 1-4-6-2-3-5
Flywheel to Auto Torque Converter Bolts = 44 Ft#
Tranny/Bell Housing Bolts = 35 Ft#
Cooling Capacity: (Dex Cool Anti Freeze)
Manual Trans C5/Z06 = 11.9 L. / 12.6 Quarts
Auto Trans. C5 = 11.6 L. / 12.3 Quarts
Dex Cool/Distilled Water:
Normal App = 50/50
Hot Weather/Racing = 30/70 * **
* THIS WILL NOT PROVIDE ADEQUATE ANTI FREEZE PROTECTION IN COLD CLIMATES BUT WILL PROVIDE BETTER COOLING IN HOT WEATHER. BE SURE TO RECONSITUTE TO 50/50 RATIO DURING COLD WEATHER
** 2 bottles of RedLine Water Wetter recommended for Racing
Diff Capacity:
Lubricant (Syn 75W90) = 1.6 L. / 1.69 Quarts PLUS (+)
Anti-Slip Additive = 118 mL. / 4.0 ounces
M12/Z06 Manual Ratios:
1st: 2.97
2nd: 2.07
3rd: 1.43
4th: 1.00
5th: 0.84
6th: 0.56
Rev: 3.28
Axle: 3.42
Overhaul/Drain & Fill = 3.9 L. / 4.1 Quarts
(Dexron III Non-Syn or Syn equivilant)
MM6/C5 Manual Ratios:
1st: 2.66
2nd: 1.78
3rd: 1.30
4th: 1.00
5th: 0.74
6th: 0.50
Rev: 2.90
Axle: 3.42
(Dexron III Non-Syn or Syn Equivilant)
M30 Auto/C5
1st: 3.06
2nd: 1.62
3rd: 1.00
4th: 0.70
Rev: 2.29
Axle: 2.73 OR 3.15
Drain & Fill = 4.7 L. / 5.0 Quarts
Overhaul = 10.2 L. / 10.8 Quarts
1 - 1 of 1 Posts
Status
