· Registered
I have a question about a using an oil cooler; forgive me if this is a dumb question or has been covered in the past.
I was reading a very good article on the ZO6 in which the author mentioned that the C5's historically had trans temp problems both with manual and automatic trans (justifying the need for the trans temp light). His suggestion was installing a trans cooler which is available from Chevrolet. I've never heard of a trans cooler for a manual trans- (how would the trans fluid get pumped through the cooler). Forgive me for my ignorance- can someone enlighten me. Also is there a trans temp readout on the ZO6 or just a warning light. Thanks in advance.
· Registered
12480080 is the GM Part number for the tranny cooler kit. It includes:
12480081 Pump Transmission Oil Cooler
12480082 Cooler - Assembly Transmission Oil
12480117 Wiring Harness
12480118 Clamp - Pump
12480087 Switch - Thermal
12480088 Package - Hardware Fasteners
