1 - 17 of 17 Posts
Dumping stock transmission fluid and upgrading to Redline D4 ATF. How many quarts do I need? Any advice or tips would be greatly appreciated. Thanks! :cheers:
Buy a magnetic drain plug
Who sells magnetic transmission and oil drain plug's?
Corvette Garage, LAPD etc they all carry them. :cheers:
Are the mag. oil and transmission plugs the same? I can only find magnetic oil drain plugs. :-?
The plugs are all different. Sent you a PM
Could someone PM me where to get the tranny plug. I will be doing this soon as well. :)
PM me too...
I would be interested as well. Why can it not just be posted here, is it not a supporting vendor?
Correct! I will send you the info as well. Don
Getting ready to install Royal Purple Syncromax would like to instal mag plug but checked various vendors ,can't find. Any suggestions.
Go through Ecklers then.
Tranny Mag plug = part #42114
Diff Mag plug = part #42115
Engine Mag plug = part #39805
Thanks IT L GO for the heads up on the mag plug,ran down to Ecklers and picked one up also the DYI was helpful.Did the change today works fine. Thanks again
Drain plugs?
Would you mind sending me a PM on the drain plugs please?
Thanks,
Terry
1 - 17 of 17 Posts
