The transmission on my 01' Z06 rattles slightly when it is idle and not in gear. The rattles goes away when I rev the engine. Is this common or should I take it to the dealer to check it out. Also, the transmission has a grinding noise when it is at running at low RPMs (from 600 - 1300) in any gear. Is this also normal??
I can't relate to the grinding but I have heard most Z's rattle when in neutral and give a REALLY nasty sound when shutting the motor off in neutral. Dealers claim this is normal and many other owners confirm this. My Z makes noise in neutral and a bit when pulling away form a stop light in 1st gear but it doen't make a grinding sound.... just rattles.
I guess it's not a grinding noise.......it's more like a series of really fast rattles then it goes away in the higher RPMs.......I guess you're saying it's normal right???
Try The Search Feature!!
Type in "Transmission rattle", "Transmission noise", and you can read until your hearts content:D
