1 - 19 of 19 Posts
I read two different articles both citing noticable amounts of heat generated and passing thru the interior via the trans tunnel....has anyone heard this as well and are they looking at addressing it.....reminds me of the c3's
The articles are correct. Noticable amounts of heat do in fact pass into the cabin from the tunnel. Who are you referring to when you ask, "are THEY looking at addressing it", the owner or the manufacturer? Some owners have removed the carpeting and seats and installed insulation and/or sound deadening material which has some effect on heat transmission.
Charlie
mcss383 said:
Who cares? Its a race car for the street! :)
:roll:
Charlie
Nothing a $250 dollar aftermarket ceramic coated tunnel sheild can't fix.
I put a coated Aluminum tunnel stiffener on my car the last time I changed my exhaust. It made a very big difference in how much is transmitted into the cabin. Even in the heat of
BG during the fest, the tunnel never got very warm, not to mention the added benefit of the chassis being much tighter and solid feeling. Great mod for $180 from Elite Engineering in Windsor, CO :thumb: :thumb:
Jim
At Carlisle, Dave Hill said this situation was improved with the new Z06...
I'm looking forward to getting one of these.
Alex :zboobie:
Whipdan said:
I too would recommend Elite in Colorado. Great prices and service. Called one day, had the plate the next morning.
Is this one made of aluminum or stainless steel? Is it ceramic coated?
TIA,
Alex :thumb:
Drive a new Viper for 3 days (we rented one when trying to decide between the Z06 and viper) and you won't even notice any heat from the Vette.
Between the trans tunnel heat and the side pipes, you need to keep the air on ALL THE TIME in the Viper
Discussion Starter · #14 ·
There seems to be some confusion here....I am talking about the new 2006 Z06. I read two recent articles about it.
TIA,
Alex :thumb:
Alex,
When you check their website, you'll see that they have both the Aluminum and stainless steel ones, both coated and uncoated. Great mod, IMHO :thumb: :thumb:
Jim
In response to concerns about transmission tunnel heat:
In the Sept. 5th AutoWeek, Dave Hill points out that those who expressed concerns about transmission tunnel heat getting into the interior, tested cars which were "were pre-productions cars lacking improved 'transmission-tunnel noise isolators'" [which were incorporated into the final production Z06's].
Hi there,
That is correct.
There is heat shielding on ZO6.
The biggest issue for this is the fact that the converters are directly in this tunnel. They burn at 800 degrees F at times.
Most models I rode in did NOT have the shield, 2 did.
It does make a different, although how much, I did not measure.
Allthebest, c4c5
Jim Lembo said:
Alex,
Jim
Thanks Jim. Which is stronger? Stainless steel or aluminum?
Alex,
The stainless steel one is probably stronger, I went with the Aluminum plate for the weight savings. When you call Jeff at Elite, he will give you all the details, or you can check out the weights of the different ones on his website. HTH,
Jim
1 - 19 of 19 Posts
