1 - 2 of 2 Posts
Hi all ... does anyone know where these can be measured on the Z06 ? Or better yet, how ?
Z Trim Height ? For Z06 FE4 it's 49mm (42.6 - 55.4 mm Toler.)
D Trim Height ? For Z06 FE4 it's 104 mm (97.6 - 110.4 mm Toler.)
J Trim Height ? For Z06 FE4 it's 152 mm (145.6 - 158.4 mm Toler.)
and
K Trim Height ? For Z06 FE4 it's 152 mm (145.6 - 158.4 mm Toler.)
Concentrate on Z and D
HI Rob,
Please concentrate on the Z and D trim heights for this problem.
Z is measured at the front suspension, as you will be measuring from the lower control arm pivot center line, to the bottom of the ball joint itself.
D is the same basic measurement, however, it is measured at the rear.
The other 2 measurements will fall into line, once these are done.
Besttoyou, c4c5:z:
1 - 2 of 2 Posts
