Vendor
You can make your great C7 Corvette even better by upgrading its exterior with lightweight carbon fiber components. These eye-catching, jaw-dropping, stylish parts can not only make your sports car unique and set it apart from the crowd but also improve its performance on the track thanks to enhanced aerodynamics and reduced weight.
Check out this collection of brilliant exterior components made from durable carbon fiber by Nowicki Autosport Design. The company was started by a former racer and Corvette champion, Jeff Novicki. These upgrades are very popular among our clients owning C7 Corvette. All of the components are carefully engineered to match factory mounting points resulting in quick and trouble-free installation.
Nowicki Autosport Design® - Hood
A strong but lightweight carbon fiber hood instantly grabs attention. It is a perfect combination of slickness and aggressiveness. Note that hood heat extractor and underside hood pad are sold separately and not included.
Features:
- Improves both style and performance
- Installed using factory hinges, hood latch, and hardware
- Motorsports-inspired design to add a stylish, eye-catching accent
- UV-resistant clear coating
- Manufactured in the U.S.A.
Fitment:
2014 Chevy Corvette
2015-2019 Chevy Corvette Stingray
2015-2017 Chevy Corvette Z51
2017-2019 Chevy Corvette Grand Sport
Nowicki Autosport Design® - Front Bumper Splitter
The front bumper splitter by Nowicki Autosport Design is designed to not only make your sports car look unique but also increase downforce for better high-speed stability, tire traction. Such an upgrade looks perfect with matching side rocker panels or side skirts.
Features:
- Creates additional downforce
- Uses original mounting locations with provided hardware
Fitment:
2014-2018 Chevy Corvette
2016 Chevy Corvette Convertible
2016 Chevy Corvette Coupe
2019 Chevy Corvette Z06
Nowicki Autosport Design® - Side Rocker Panels
These carbon-fiber panels designed by Nowicki work flawlessly in conjunction with the front bumper slipper by the same manufacturer to create an ideal balance between drag and downforce. Their job is to minimize the amount of air coming under the car from the sides at high speed.
Features:
- Improve high-speed balance
- Protect other parts of the body from debris damage
- Gives the vehicle a unique, aggressive look.
Fitment:
Fits all 2014-2019 Chevy Corvette versions.
Nowicki Autosport Design® - Rear Diffuser
Even though the rear diffuser doesn’t seem important, it performs an essential function of improving your Corvette’s aerodynamics by smoothing out the transition between the powerful airflow from under the car and slower air massed in the ambient atmosphere. Note, that the installation requires removal of the rear bumper cover.
Features:
- Improves aerodynamics
- Gives the vehicle a unique, racing car style
- Can be attached using factory mounting hardware
- Can come with OE matching tint (optional)
Fitment:
Nowicki Autosport Design® - Front and Rear Fender Flares
Carbon-fiber fender flares by Nowicki Autosport Design are created as a simple and affordable alternative to expensive bodywork needed if you decide to install wider tires. Besides, they look sleek. Most states have legal requirements stating that fender flare must cover the tire or at least tread blocks.
Features:
- Add Z06-sized front and rear tires and wheels to your Stingray/Z51 without an expensive widebody conversion
- Front and rear fender flares are 25MM wider at axle centerline to allow 19x10.5" front and 20x12" rear wheels on your Stingray
- Genuine 3K carbon fiber twill matches factory OE carbon fiber pattern
- Manufactured in the USA
- Available in fiberglass variant
Fitment:
2014 Chevy Corvette
2015-2019 Chevy Corvette Z06
2019 Chevy Corvette ZR1
Let us know what you think about these body upgrades. If you have any questions, feel free to ask them in this thread, personal messages, or contact our help center at CARiD.com
Vendor
Discussion Starter #3
It really is! Unlike some of the inexpensive kits on the market, these parts line up perfectly thanks to the more precise design. It one of our newest brands and the quality level is outstanding. If there are any C7 owners on the forum - we highly recommend checking out.
