Anyone know what they will have to do to replace a melted turn signal light? What do they need to remove? If there was heat in the area enough to melt the light, what else could it have done.
Should be an easy fix. Did it do any damage to the paint?? Is the area around the melted turn signal wavy?? If not then it will be a piece of cake for your local body shop:)
If no paint damage, then nothing else should be damaged.
Body shop!?!?!? No way in hell should you pay a body shop. Take 30 minutes to an hour to replace it. There are panels under the front of the car that you can unbolt in about 30 seconds. You might be able to do it without even lifting the car...
