I have ccw 505A on the rear 19x11. I installed the front with no problem, but the rear calipers are hitting the rim. Has anyone tried to install two piece rears on 505A ccw? The factory zo6 rears fit fine with rotors.
You have two choices:
1- add spacers. these are tiny (maybe an 1/8th" or so -- less then 5mm).
2- grind your calipers down, and then paint. The thing with this is that the stock setup is a floating one. So when it heats up, you will lose even more clearance.
I am in the same position as you.
Call up CCW they can make you a set of spacers for yah.
-N
I called John at ccw. He is going to make me a set of spacers! Thank's for the suggestion. John is a super nice guy. They have excellent customer service. When I buy my next set of wheels one day they will be from them. :usa:
