1 - 1 of 1 Posts
well I put in the BB Bullet exhaust and love it...but at the same time found out that the axle is leaking. did a search and found this is common..so I will be calling the dealer tomorrow.
Now, I also found out that the rocker panel, I think that is what it i scalled is cracked. I guess Just Tires put the lift on the rocker...had to get a flat repaired down south. Too late to blame them since it was done a long time ago.
Well, do these cracks spread or will it be okay...it bothers me that it is cracked, but you cant even see it since it is underneath. Do I need to repair it so it wont crack, or would it e okay.
1 - 1 of 1 Posts
