1 - 13 of 13 Posts
Which under drive to install with no problems with electrical system, 10% or 25%- is there something in the middle.
How much power is their to be made with each.
Please chime in.
This is an easy mod, that i have not done yet...
I was told the ASP pulley is kind of tricky to install and could result in vibration problems if not done correctly. Also, there could be clearance issues if you have a dual roller timing chain. As mentioned, not worth it unless you are doing a cam install at the same time. :thumb:
Bob
Before s/c I had the MTI pulley. No problems with ac or alternator.
Got 6 rwhp on a stock block.
If you are not doing a cam at the same time you have to ask yourself is 6 hp worth the $s.
Icewasp said:
Cool.....So a 25% under drive pully would render the alternator 25% less effective?...Just confused on the math here... :crazy:
It will just means everything will turn 25% slower at any given RPM. Which may or may not cause a charging problem during extending periods of Idling or if you have a big time stereo amps. :cheers:
IT L GO said:
It will just mean everything will turn 25% slower at any given RPM. Which may or may not cause a charging problem during extending periods of Idling or if you have a big time stereo amps. :cheers:
With a stock power draw (ie no killer stereo added), you will be alright under most driving conditions. Never have had a problem using them on other cars in the past, but I'm not one to idle for long... :p
I am using one and have no problems with lights, ac etc.
Volts are still at 14.3 at night, normal cruise
But you need a cam for all that work.
DITTO!
Go for it when you do a cam..its seamless but not worth the money imho without a cam mod.
HTH
1 - 13 of 13 Posts
