I had a damaged engine (piston and some valves and the cam) due to timing chain bolts breaking.......Anyway, i went for the stealth cam II, comcams dual springs, and a local slight porting of the heads, also 202/1.6 valves. The whole job should be done by the weekend. other mods i have already done are pulley,flywheel, Haltech trap.
My question is after all the work is over, how would i use the predator programmer? As i understand it, i have the following options:
1- Download performance file as usual
2- Download Head/Cam file ive been told exists
3- Rent a dyno and use programmer(no tuners here)
4- Chuck it in the bin or sell it i mean!
Any advice guys for an inexperienced Zo6(2002) owner??
Yes you CAN use the Predator to program for H & C. You will have to call then with your specific mods and they will custom make a program for you.
A dyno will still help to achieve the max output.
Thanx,Is there a H/C program already in the predator i can download?
NO, there is not.
If you put the stock program from the Predator you will probably lose power. You need a custom program.
You seem to be making some nice power with the few performance mods you have, especially with that predator tune. So who should i contact for a custom file to be sent to me? Any idea on prices?
Less importantly at this stage, how much power can i expect to increase with that tune with the mods i stated above vs leaving stock tune? is it really necessary when you slightly port the heads with the new cam i chose? :eek2:
They can give you an emailed tune for your predator after filling out all the info. Cost is approx. $100.00 from a dealer. You also need to buy the Predator/PC interface. You will definitely leave hp on the table though, but the drivability will be good. There is nothing as good as a dyno tune.
Diablosport does have "canned files for heads and cam..
I'm considering going with a P1SC setup for mine. I've attached an email to Johan (Diabosport's GM custon R&D guy)
He already had a "blower program ready to go..
I've edited the email due to Diablosport's copyright rules.
-----Original Message-----
Sent: Friday, July 01, 2005 17:35
To: Undy
Subject: Re: tune for an 04 Z04
Here is a starter file for #42's and 7psi, timing might be on the
aggressive side so please monitor the spark.
Sincerely:
> Hi ,
> Long time no speak... About a year ago you did 4 or 5 custom programs
> for my 04 Z06 and emailed them to me at . The car had long
> tube 1 3/4" headers, hi flow cats, and a B&B PRT exhaust.. BTW.. It's
> been running flawlessly ever since w/ 388 rwhp! It's now time to step
> on the Vette it a little. I'm getting ready to install Andy's A&A
> procharger P1SC system on it with about 7 psi of boost. His typical
> net rear wheel hp is 550 SAE with the kit. It'll have the 42lb
> injectors along with a Boost-a-Pump for the fuel. The exhaust will
> remain the same. Can you hook me up with a program to get me runnin'?
> My VIN's .
> Thanks again,
> Dave
