I had a quick question for other vararam people.. When you reinstalled the fan shroud, did it press up against the vararam scoop units? My shroud seems to press right up against the scoops, but the scoops are as steep as I can get them. I had to take a break from the install, and the shroud fit into the nose just fine, so I'm guessing its normal, but I wanted to check in with the experts just the same.
Thanks! :cheers:
Ben
Thanks alot!
Thanks again for the replies. Sounds like my fit is par for the course. Hopefully I'll have an opportunity to tighten everything up this evening and fire 'er up.. :jammin:
